2.4 GHz profile after rebooting needed for firmware upgrade
GiuseppeR
GiuseppeR Posts: 554 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
it is the second time (in two different Companies) that it happens that after a reboot needed for a firmware upgrade the 2.4 GHz wifi profile does not work properly:
For example this morning I had a printer that was not able to connect wirelessly with the AP after the V7.00(ABYW.2) update: it was sufficient to reboot the AP to let the printer goes online.
Same thing happened in the previous V7.00(ABYW.1) update from 6.55 (if I remember its release number correctly) with another production site.
Anyway it seems a random issue: I have multiple sites, only few reports
  • GiuseppeR
    Hello @Marlene495Hadley
    am I chatting with an AI made for spamming communities like this one?
    PeterUK Posts: 4,272 image  Guru Member
    edited September 2024
    Is it a HP printer?
    I have mine to a USG60W and it goes offline after some hours being on and have to press the power button on printer to connect.
    It could be that as the AP goes off line when doing the firmware for a long time the printer goes offline or sleep mode
  • GiuseppeR
    It is an EPSON WorkForce, setup for always on and standby after 5 mins of no activity.
    A part from when the Company has blackouts that EPSON is always ready for printing.
    Those two different disconnections for two different Companies (after AP firmware upgrade) happened with that printer which I was referring to earlier and with a Daikin A/C unit, exactly the morning after a scheduled firmware upgrade of the AP.
    For this reason I highlighted some doubts on that happening.
    To be sure I rebooted firstly the appliances (printer and the A/C unit) but this action does not solved the problem while rebooting the AP fixed the connection issue.
  • Zyxel_Nami
    Zyxel_Nami Posts: 659 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    Hi @GiuseppeR
    As we discussed via message, the issue you're experiencing appears to be similar to one previously mentioned on the forum:
    However, to determine if it is the same issue, we need to review the diagnostic information from the AP. Please collect the diagnostic info from the APs when the issue reoccurs and send it to us via private message for further investigation.
    Additionally, has the issue only occurred with the printer, or have you also tried connecting a mobile phone or desktop to the 2.4GHz network?
    Nami
  • GiuseppeR
    Hello @Zyxel_Nami
    I use 2.4 GHz spectrum mainly for IoT things (e.g. printers, sensors, A/C units).
    Mobile devices go to 5 GHz.
  • Zyxel_Nami
    Hi @GiuseppeR
    Regarding the case I mentioned earlier, where the 2.4GHz was not visible to clients, could you please help verify if your issue is the same? You can do this by checking if the IoT devices/desktop/phone can detect the 2.4GHz SSID.
    Nami
  • GiuseppeR
    Hello @Zyxel_Nami
    the 2.4GHz SSID was not reachable by IoT things, they could not see that network.
    Rebooting the AP solved the issue
Nebula Tips & Tricks
