LTE5398-M904 - Disconnection under Iliad Operator
Andy_Queen
Andy_Queen Posts: 2 image  Freshman Member
Hi There
My Router has more disconnection ( LINK UP, NO TRAFFIC ) with Italian ILIAD Operator.
Many users has got this issue.
Are there some workaround to fix it ?
Last firmware doesn't fix this issue.
Waiting from some good news.
Cheers
Andrea
  • Bob_C
    Bob_C Posts: 222 image  Master Member
    What is your module firmware version?
    You may check it on Cellular WAN Status (Monitor > Cellular WAN Status).
    Regards,
    Bob
  • Andy_Queen
    Hi Bob
    Here Is It firmware version
    EG18EAPAR01A11M4G
  • ivx675
    ivx675 Posts: 10 image  Freshman Member
    First Answer First Comment First Anniversary
    My router started doing same in last months. Works 1-2 weeks, then no internet. If i login to router, shows cellular connection is up and ok. Only router restart will fix it.
    I have latest firmware:
    Modem firmware: EG18EAPAR01A12M4G
    Router firmware: V1.00(ABQV.4)C0
    I also have static cellular IP, so it's not relayed to wan ip refreshing.
  • ivx675
    I disabled(currently use separate wifi AP) 2.4G and 5G wifi, seems to work ok after it.
