First time caller... be gentle...
kizzed
kizzed Posts: 2  Freshman Member
I purchased a NAS326 from an online seller. Now, when I reset it defaults to a name and pass that he set… Weird thing? As long as the username is correct it will not error out. It will just keep loading
  • suisei
    suisei Posts: 118  Ally Member
    First Comment First Answer Friend Collector Second Anniversary
    You might consider resetting the NAS326 and performing a firmware recovery using a USB disk to restore it to default settings and prevent any issues from the previous user.
    Index of /Users/Mijzelf/RescueSticks (zyxel.diskstation.eu)
  • kizzed
    I did just that, funny thing was it didn't take until the 3rd time. Now I am trying to figure out if it is even worth trying to use the stock OS, nothing can really be updated. BTW Thank you for replying!
