One 7101, multiple locations, multiple WIFI routers
ArjenSmedes
I have a 7101 outdoor router, which is now connected to a 5101. That setup works great. However, the plot of land that I live has two house, which are some 10 meters apart. I'd like to know what additional hardware I can buy to have the following:
- In one house, the 7101 will be on the roof
- In both houses, I'd like (not necessarily the 5101 included) a WIFI router (or simply two access points) attached to the 7101 (albeit through a switch).
Does somebody have any experience with it? And which switch/routers are you using for it?
From one house to the other I could draw a UTP cable, but if someone has a setup or recommendation to only have wireless routers instead, I'd be happy too.
Regards,
Arjen.
Hi @arjen,
My NR5101 use as a mobile router, I simply insert the SIM card to provide cellular wan connection.
And NR7101 is connect to a CPE (EX3301 for example)
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
