Session Control and YouTube Restricted Mode
robert_loesch
robert_loesch Posts: 2 image  Freshman Member
edited September 2024 in Security
After the firmware update V5.38(ABTJ.0) for ATP700 the session control limit was set to 8192, I have no idea where this number came from, besides users couldn't browse anything, even though the Internet was working, till I deactivated the session Limit.
Should I enable and set the limit to 0 (unlimited) or should I let it disabled.
Another Problem:
Restircted Mode was also activated after the firmware update. YouTube comments are disabled and some Live Webinar wouldn't work.
Any Idea how to solve this problems, please.
Thanks a lot in advance.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    Hi @robert_loesch ,
    Issue 1: Could you provide your firewall's configuration file (start-up config) and diagnostic file for us to check?
    Issue 2: Could you describe more detail about "Comments are disabled and some Live Webinar wouldn't work.", ?
    Zyxel_Judy
    Untitled Image
  • robert_loesch
    Hi @Zyxel_Judy
    I've already edited the question above.
    What exactly do you wanna know in configuration file? because you know it has all the information of the company I work for 😉.
    About the comments I meant on YouTube.
    PeterUK Posts: 4,340 image  Guru Member
    It seems the your hitting a limit thats been set by you? Or someone else?
    The default session per host is a bit low
    This could indicate something bad is happening on your network like a DoS flood from devices.
  • Zyxel_Judy
    Hi @robert_loesch ,
    The method to download ATP700's configuration file (start-up config) here:
    [ATP/FLEX] How to download configuration file on Firewall Local WEB GUI? — Zyxel Community
    The method to download ATP700's diagnostic file here:
    [ATP/FLEX] How to collect diagnostic file on Firewall Local WEB GUI? — Zyxel Community
    After we receive your files, we'll review them and inform you of any findings.
    In the meantime, please check with your colleagues to see if anyone has made changes to the YouTube settings.
    Zyxel_Judy
    Untitled Image
