NWA1123-AC in Nebula network possible?
Hi @Wallie ,
To clarify, the NWA1123-AC is not supported for management via Nebula. You can manage it by Standalone mode only.
Apologies for the confusion regarding the model's name.
FYI: NWA1123-AC reached its End of Life (EOL) on 2018/12/31. For optimal performance, we recommend exploring our current switch offerings here:Zyxel_Judy
Hi, Thank you for the explanation. However, I think the NWA1123-AC is not compbatible for the nebula network.
When I enter the Mac Adress and Serial number I get this message: Model is not supported by NCC.
When I look at the list of supported devices I get this list:
NAP102, NAP203, NAP303, NAP353
- NWA1123ACv2, NWA1123AC-PRO, NWA1123-AC HD, NWA1302-AC, NWA5123-AC HD, NWA1123ACv3
- WAC6303D-S, WAC6103D-I, WAC6502D-E, WAC6502D-S, WAC6503D-S, WAC6552D-S, WAC6553D-E, WAC5302D-Sv2
- WAC500, WAC500H
- NWA110AX, WAX510D, WAX650S, WAX610D, NWA210AX, WAX630S
- NWA50AX, NWA90AX, NWA55AXE, NWA50AX PRO, NWA90AX PRO
- WAX655E
- WAX620D-6E, WAX640S-6E, NWA220AX-6E
- WAX300H
- NWA130BE, WBE530, WBE660S
The
NWA1123-AC is not mentoined in the list. I see that NWA1123ACv2, NWA1123AC-PRO, NWA1123-AC HD and NWA1123ACv3 are compatible. The NWA1123-AC without any additional letters is probably not.
So again my question: Can I use the NWA1123-AC in the Nebula network?
Hi @Wallie ,
- 441 Beta Program
- 292 Service & License
