NWA1123-AC in Nebula network possible?
Wallie
Wallie Posts: 2 image  Freshman Member
I have two access points NAP102 in a Nebula network. Now I want to add another access point. Type NWA1123-AC SN: S162L17141251
Is it possible to add this access point to the network? It looks like that it is not possible.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,320 image  Zyxel Employee
    edited September 2024 Answer ✓
    Hi @Wallie ,
    To clarify, the NWA1123-AC is not supported for management via Nebula. You can manage it by Standalone mode only.
    Apologies for the confusion regarding the model's name.
    FYI: NWA1123-AC reached its End of Life (EOL) on 2018/12/31. For optimal performance, we recommend exploring our current switch offerings here:
    https://www.zyxel.com/us/en-us/products/wireless
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @Wallie ,
    You can add the NWA1123-AC to Nebula. You can find the guide here:
    Zyxel_Judy
    Untitled Image
  • Wallie
    Hi, Thank you for the explanation. However, I think the NWA1123-AC is not compbatible for the nebula network.
    When I enter the Mac Adress and Serial number I get this message: Model is not supported by NCC.
    When I look at the list of supported devices I get this list:
    • NAP102, NAP203, NAP303, NAP353
    • NWA1123ACv2, NWA1123AC-PRO, NWA1123-AC HD, NWA1302-AC, NWA5123-AC HD, NWA1123ACv3
    • WAC6303D-S, WAC6103D-I, WAC6502D-E, WAC6502D-S, WAC6503D-S, WAC6552D-S, WAC6553D-E, WAC5302D-Sv2
    • WAC500, WAC500H
    • NWA110AX, WAX510D, WAX650S, WAX610D, NWA210AX, WAX630S
    • NWA50AX, NWA90AX, NWA55AXE, NWA50AX PRO, NWA90AX PRO
    • WAX655E
    • WAX620D-6E, WAX640S-6E, NWA220AX-6E
    • WAX300H
    • NWA130BE, WBE530, WBE660S
    The
    NWA1123-AC is not mentoined in the list. I see that NWA1123ACv2, NWA1123AC-PRO, NWA1123-AC HD and NWA1123ACv3 are compatible. The NWA1123-AC without any additional letters is probably not.
    So again my question: Can I use the NWA1123-AC in the Nebula network?
  • Zyxel_Judy
    Hi @Wallie ,
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
