I need to reset my password so that I can access EX3301-T0
Johna
Johna Posts: 3 image  Freshman Member
edited September 2024 in Home Router
I want to set up two wifi, and for that I need to log in. I dont have my password and need to reset it
  • Liba
    Liba Posts: 208 image  Master Member
    First Comment First Answer Third Anniversary
    Normally you can find the login password on the back label.
  • Johna
    Yeah and I have tried it but I still can not log into http://192.168.1.1/login. . I dont know who to contact since I cant find a number for support. Any help would be apricated
  • Peter2
    Peter2 Posts: 176 image  Master Member
    edited October 2024
    You have to make a factory reset to rebuild the initial password printed on the back :
    like this :
    https://www.youtube.com/watch?v=fFtNi7lEOt8
  • Johna
    Okej thank you, will try it tomorrow and come back with the results
