NWA50AX not registered by NCC - used to work perfectly
pescatoreDiStelle
pescatoreDiStelle Posts: 4  Freshman Member
AP not detectable by clients even though connected via PoE to EX3300-T0 router.
The router can ping it (using the 192.168.1.1 menu) on the IP adress with success. In the nebula app I can ping a URL with the AP and it says sucess. Updated firmware of router and AP. Followed the AI guide on nebula; SSID settings (enabled, no schedule, WPA2-PSK). I dont understand why it just wont work as it has. LED of AP is blinking green with 3s frequency.
from the monitor eventlog in nebula control center below:
02-10-2024
12:59:19
B8:D5:26:FF:66:2C
User
Fail login attempt to NWA50AX from ssh (login on a lockout address) [count=4]
02-10-2024
12:59:12
B8:D5:26:FF:66:2C
User
Fail login attempt to NWA50AX from ssh (login on a lockout address) [count=2]
02-10-2024
12:59:07
B8:D5:26:FF:66:2C
User
Fail login attempt to NWA50AX from ssh (login on a lockout address) [count=3]
02-10-2024
12:59:03
B8:D5:26:FF:66:2C
User
Failed login attempt to NWA50AX from ssh (incorrect password or inexistent username)
02-10-2024
12:58:55
B8:D5:26:FF:66:2C
User
Fail login attempt to NWA50AX from ssh (login on a lockout address) [count=5]
02-10-2024
12:58:43
B8:D5:26:FF:66:2C
User
02-10-2024
12:58:41
B8:D5:26:FF:66:2C
User
Address 183.81.169.238 has been put into lockout state
02-10-2024
12:58:29
B8:D5:26:FF:66:2C
User
Failed login attempt to NWA50AX from ssh (incorrect password or inexistent username) [count=5]
02-10-2024
12:58:11
B8:D5:26:FF:66:2C
User
02-10-2024
12:58:00
B8:D5:26:FF:66:2C
User
02-10-2024
12:57:47
B8:D5:26:FF:66:2C
User
02-10-2024
12:57:27
B8:D5:26:FF:66:2C
User
02-10-2024
12:57:16
B8:D5:26:FF:66:2C
User
02-10-2024
12:56:55
B8:D5:26:FF:66:2C
User
02-10-2024
12:56:46
B8:D5:26:FF:66:2C
User
02-10-2024
12:56:37
B8:D5:26:FF:66:2C
User
Address 83.222.191.62 has been put into lockout state
02-10-2024
12:56:18
B8:D5:26:FF:66:2C
User
Failed login attempt to NWA50AX from ssh (incorrect password or inexistent username) [count=2]
02-10-2024
12:55:56
B8:D5:26:FF:66:2C
User
02-10-2024
12:55:45
B8:D5:26:FF:66:2C
User
02-10-2024
12:55:21
B8:D5:26:FF:66:2C
User
02-10-2024
12:43:31
B8:D5:26:FF:66:2C
User
02-10-2024
12:41:04
B8:D5:26:FF:66:2C
User
02-10-2024
12:35:45
B8:D5:26:FF:66:2C
User
02-10-2024
12:20:21
B8:D5:26:FF:66:2C
User
02-10-2024
12:18:22
B8:D5:26:FF:66:2C
User
02-10-2024
12:17:56
B8:D5:26:FF:66:2C
User
02-10-2024
12:17:55
B8:D5:26:FF:66:2C
User
Nebula Tips & Tricks
