Application overvieuw nebula
Dpj
Dpj Posts: 174  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
in nebula we have an option Application Usage. Is it possible to create our own application here, so we can get a detailed view how much our own application consumes?
  • Zyxel_Kay
    Zyxel_Kay Posts: 1,279  Zyxel Employee
    Hi @Dpj
    Could you share more details about the specific application you're looking to monitor? The Application Usage feature currently offers two views: Category View and Application View. You can check the usage of specific applications by selecting the Application View at the top right of the interface:
    At this time, custom applications cannot be added directly within the Application Usage feature. The focus is on tracking bandwidth consumption of predefined, commonly used applications.
    Kay
  • Zyxel_Kay
    Hi @Dpj
    Kay
  • Dpj
    Its an application hosted in azure. It's not urgent, but was just wondering if something like that is possible. So thank you for your answer!
Nebula Tips & Tricks
