VPN Site to Site Mikrotik to Zyxel flex 700
Best Answers
Hi @duythượng,
Mikrotik side doesn't send any traffic, have you checked the security policies that are allowed for the VPN?
Zyxel Melen0 -
Update conclusion:
The VPN configuration on USG FLEX or Mikrotik side are both correct. This issue is due to the special topology that has some policy route rule that cause the traffic cannot pass to the correct interface. Adjust the policy route rule fix the issue.
Zyxel Melen0
Hi @duythượng,
Zyxel Melen0 -
Thank you for your response:
I have tried the mikrotik router side with the same phase configuration as the Draytek Router, the connection is normal, ping between the 2 routers is normal. Can you help me check the Zyxel side about the phase, I am currently configuring the phase as follows:0 -
Thanks Melen for the support the problem was resolved beyond expectation. Thanks Zyxel team for providing us with a very good service. Five star rating for the quality of service
Update conclusion:
Zyxel Melen0
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 491 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
