Having trouble to get NAT working
JonBl
Hi.
I've got a FWA710 in router mode and can't access my network via port forwarding (NAT).
I've set up the NAT page like this
Ive tried to cange WAN-interface to default but no success.
Firewall are set to low.
I've rebooted several times.
Any clues on what I've set up wrong?
Thanks for any help
Jonny
Hi @JonBl,
You might need to check with your ISP if your IP is able to use NAT port forwarding.
Zyxel Melen0 -
Hi.
The problem was ISP blocking incoming requests.
Solved this by changing APN to internet.public
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
