FWA710 scheduled reboot
meganie
meganie Posts: 2 image  Freshman Member
Hi, could you add a scheduled reboot option to the firmware of the FWA710 as you did with the NR7101? https://community.zyxel.com/en/discussion/comment/47134/#Comment_47134
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,604 image  Zyxel Employee
    Hi @meganie,
    FWA710 schedule reboot feature is on the Nebula device detailed information page > device status. For more information, please reference the release note below:
    [Release Note] Nebula Control Center - 17.20 software Release! — Zyxel Community
    Zyxel Melen
  • meganie
    And if I don't want to use the cloud?
  • Zyxel_Melen
    Hi @meganie,
    FWA710 is a Nebula 5G NR mobile router. We recommend using the cloud to have complete functions. In addition, the Nebula schedule reboot supports multi-select. You can choose any day you want, like the weekday schedule reboot.
    Zyxel Melen
  • Ted_mazzone
    Ted_mazzone Posts: 1 image  Freshman Member
    Excuse me, i’m a private home user and i’m also concerned about Scheduling reboot of my FWA710 without purchasing a cloud lease plan. I’m not interested in multi-select or any other fancy stuff, i’m just trying to keep it simple after purchasing a top notch cpe. Can you please tell me how to schedule reboot my device from the gui and/or using command line? Thanks
  • Zyxel_Melen
    Hi @Ted_mazzone,
    No, schedule reboot function is only supported on Nebula for FWA series. In addition, the schedule reboot function doesn't need to purchase additional license to use. You may set your own schedule although your organization is a base-pack organization.
    Zyxel Melen
