FWA710 - Latest firmware slowing download speed
nsmith
nsmith Posts: 28 image  Freshman Member
edited October 2024 in Nebula
Hi all - I recently upgraded my FWA710 to the latest firmware, v1.18(ACGC.4)C0, and noticed the download speed was slower. I downgraded to v1.18(ACGC.2)C0 which seems to fix the issue.
Has anyone else noticed the same thing with the FWA710 on the latest firmware?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,316 image  Zyxel Employee
    Hi @nsmith ,
    Could you provide more details on how you tested the speed with firmware versions 1.18P2 and V1.18P4?
    • Which testing tool did you use?
    • Did you use the same SIM card for both tests?
    • Can you confirm if the FWA710 was using the same technology (NR5G-SA, NR5G-NSA, or 4G) during both tests?
    • Were the number of connected devices and applications in use the same during each test?
    Zyxel_Judy
    Untitled Image
  • nsmith
    Hi Judy - I've already opened a case with support, I was just wondering if anyone else had experienced the same issue.
    It's using NR5G-SA with 1x device connected, same SIM card and using nperf & Ookla for the tests.
Nebula Tips & Tricks
