FWA710 - Latest firmware slowing download speed
Hi all - I recently upgraded my FWA710 to the latest firmware, v1.18(ACGC.4)C0, and noticed the download speed was slower. I downgraded to v1.18(ACGC.2)C0 which seems to fix the issue.
Has anyone else noticed the same thing with the FWA710 on the latest firmware?
Hi @nsmith ,
Could you provide more details on how you tested the speed with firmware versions 1.18P2 and V1.18P4?
- Which testing tool did you use?
- Did you use the same SIM card for both tests?
- Can you confirm if the FWA710 was using the same technology (NR5G-SA, NR5G-NSA, or 4G) during both tests?
- Were the number of connected devices and applications in use the same during each test?
Hi Judy - I've already opened a case with support, I was just wondering if anyone else had experienced the same issue.
It's using NR5G-SA with 1x device connected, same SIM card and using nperf & Ookla for the tests.
- 432 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 387 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
