ZyXEL SBG3500-N000 configuration for VDSL via 1&1
Svenno
Svenno Posts: 3  Freshman Member
edited October 2024 in Home Router
I try to configure my SBG3500-N000 to be able to connect to the internet. My login data are correct, as they are working with another router. But I got the message "The SBG3500 cannot connect to the internet. Please check WAN settingsor contact your ISP.".
My provider is 1&1 from Germany.
xDSL Statistics showing:
Mode: VDSL2 Annex B
VDSL Profile: Profile 17a
Traffic type: PTM Mode
Is it a question of firmware update? My firmware is V1.01 (AAON.4)
Thank you in advance!
  • Peter2
    Peter2 Posts: 168  Master Member
    edited October 2024
    You should post a picture of the menu Network/setting/broadband to configure
    There you configure "VDSL over PTM" - deactivate over ATM
    "Routing " "PPPOE"
    activate Vlan p=0 q=7 MTU 1492
    In PPOE you have to put in PPP username like this 1und1/+++++++@online.de
    get your adresses automatic
    The device is old , but seems to be prepared for VDSL Vectoring profile 17a !
    If not you have to use an external modem .
    it seems there is a firmware SBG3500-N000
    V1.01(AAON.9)C0
    https://www.zyxel.com/service-provider/global/en/security-update-zyxel-cpe-devices-and-small-business-gateways
  • Svenno
    Thank you Peter2.
    I used your configuration, but unfortunately it didn't changed anything. Here are the required screenshots.
    Screenshot 2024-10-16 213825.jpg Screenshot 2024-10-16 213849.png Screenshot 2024-10-16 213921.png
  • Peter2
    edited October 2024
    1und1 often uses ds-lite for new accounts , then you dont have a real IPv4 Adress only one over CGNAT . Try IP V6 only if you obtain a IP V6 adress single. Try a Fritz box which ds lite capable if you have ds-lite . This device must be configured for ds-lite if thats true if it is even capable.
    You are here in the home router consumer section , there is a professional security section .
    There is another one with your firmware Question , post there too …
    https://community.zyxel.com/en/discussion/21280/searching-for-firmware-sbg3500-n000
