missing security options
Dpj
Dpj Posts: 215 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
I miss a few security settings which can be done easily onpremise with Zyxel.
Mac based Vlans
Port Security (mac learning)
I really hope all on premise options (especially security) will come to Nebula!
yours dennis
2 votes
Active · Last Updated
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,651 image  Zyxel Employee
    Hi @Dpj,
    Could you share the specific scenario or application where you would like to use MAC-based VLAN? Your detail feedback will help us evaluate the feasibility of implementing this feature.
    For the port security part, we already have this feature on Nebula, which is under Configure > Switches > Authentication page. You may reference this FAQ:
    How to configure MAC Authentication via Nebula Cloud Authentication Server (NCAS) on Nebula switch — Zyxel Community
    Zyxel Melen
  • Dpj
    does the usf flex also have port security?. I would like to prevent someone can plug in an cable to the USG and can gain access to the network of the customer. what are other common solutions for this?
  • Dpj
    We were thinking for a situation like this: we put the devices we know on a specific vlan (so mac based vlan) and this are the pc's from the customer. We want to prevent that others can enter this vlan. al others go to an other vlan.
    PeterUK Posts: 4,438 image  Guru Member
    edited October 2024
    so this is MAC based vlan but you should note that it is not security due to to way it works
  • Dpj
    thank you. Very nice community with usefull information, and very active also!
  • Zyxel_Melen
    Hi @Dpj,
    We will monitor the comments and votes of this idea for MAC-based VLAN feature. Anyone likes this idea, please don't hesitate to leave your comment and give it a vote.
    Zyxel Melen
  • SkyGoat
    SkyGoat Posts: 41 image  Freshman Member
    First Answer First Comment Friend Collector Third Anniversary
    I am also very interested in having MAC Based VLAN feature in Nebula.
    Would also like it combined with a compound authentication feature.
    https://community.zyxel.com/en/discussion/24089/nebula-switch-authentication-supports-compound-authentication-configuration
Nebula Tips & Tricks
