templates for organisations
Dpj
Dpj Posts: 211 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
to start with this, you have to know how we work. we have many the same kind of customers. Al the same kind of jobs. So all our setups are basically the same.
I think it would be nice for us. (and maybe others) when we could make one template, like::
the same kind of setup of firewalls
the same kind of setup of Access points
and the same kind of setup for switches.
to make it more clear. i would like, to have always the same kind of port configuration for example. Port 24 as trunk, port 23 as trunk all the others as access
A basic SSID name for example
so we can create a new organisation and site, and then copy the organisation template we created before. We just have to adjust the SSID name a little, install the other hardware , and we are up and running.
i hope my meaning is clear.
1 votes
Active · Last Updated
Nebula Tips & Tricks
