[NEBULA] Management VLAN is send tagged over each port
Hi @KariS
If you'd like to prevent management VLAN traffic from being sent to other switch ports, you can disable the management control settings on the specific ports. For guidance, you can refer to this article:
Please note that any configurations made locally on the switch won't be synced to Nebula Control Center (NCC). Therefore, we recommend configuring most of your switch settings through NCC to avoid any conflicts. If certain settings cannot be configured via NCC, you can manage those locally, but be aware that future changes made on NCC could override local settings.
Kay
Hi @KariS
Kay
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 486 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 452 News and Release
- 4.3K FAQ
- 93 Security Highlight
