How can I change the categories of event on when using a local syslog server
ColinS
ColinS Posts: 4 image  Freshman Member
I am using a local syslog server for one of my sites and the verbosity of the logs is generating huge amounts of data, how can I select only the events I want to see?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    Hi @ColinS ,
    Currently, Nebula pushes all logs to the local syslog server. If you'd like to save specific logs on your syslog server, you can develop a filter feature when developing your local server. This allows you to save only the events you want.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @ColinS ,
    Are you referring to this feature? If so, currently, there is no option to select specific events or log types to save.
    Could you let us know which Zyxel device you're using and what type of log you want to save separately? Additionally, please share the reason for this request.
    Zyxel_Judy
    Untitled Image
  • ColinS
    Hi Judy,
    Yes, the syslog server AP log is the feature I am using and it is directed to a local device.
    The device(s) I am using is (are) two NWA1123-AC Pro.
    The log I want to capture is the system events, device registration including roaming and potentially the data stats per device. And any security alerts, errors or failures which may occur
    The reason for the request is I am trying to develop a local server to allow logging across the lan for performance in all eventualities but since migrating from local management to Nebula management the verbosity of the syslog is rendering too many events on the syslog and I cannot control the event log options
  • Zyxel_Judy
    Hi @ColinS ,
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
