[Release Note] Zyxel Access Point - V7.00 Patch 3 firmware has been released
Access Points Firmware Release Note
October 2024
Overview
This document provides firmware release information on Zyxel Access Points platforms, introduce new Access Points, new features and enhancements, bug fix, known issues and workarounds information for Release V7.00 Patch 3 C0.
Supported Platforms
(Click Hyperlink to download the firmware directly)
WiFi 7 model(s):
Zyxel WBE660S - V7.00(ACGG.3)C0
Zyxel WBE530 - V7.00(ACLE.3)C0
Zyxel NWA130BE - V7.00(ACIL.3)C0
New Features and Enhancements
N/ABug Fix
Bug fix | C | M | S |
1. [eITS: 240600705] [Symptom] Stations on certain SSIDs can't ping each other | V | V | V |
2. [eITS: 240700214] [Symptom] SSID schedule doesn't start correctly | V | V | V |
3. [eITS: 240801694] [Symptom] Layer 2 isolation not working as expected when using dynamic VLANs | - | - | V |
4. [Symptom] Enabling MLO may occasionally cause the WLAN interface to temporarily go down | V | - | - |
Known Issue
Known Issue | C | M | S |
1. [eITS: 240901112] [Symptom] MLO disabled on Nebula but enabled on AP | V | - | - |
2. [eITS: 240900715] [Symptom] Default SSID appears after Nebula AP update | V | - | - |
3. [eITS: 241000129] [Symptom] Device kernel panic reboot | V | V | V |
Limitation of Settings
N/A
Hi, since update (NWA130BE) i saw something like a system crash. SSID offline, Services restarting.
Log attached.
Next one:
2024-10-22 14:05:11Zyxel-IndoorSystemThe AP has successfully booted.
2024-10-22 14:05:11Zyxel-IndoorZyxel One NetworkZDP: initial port 2 control block
2024-10-22 14:05:11Zyxel-IndoorZyxel One NetworkZDP: initial port 1 control block
2024-10-22 14:05:08Zyxel-IndoorSystemDevice is rebooted by kernel panic!
Sigh my Kernel panics are back again as well. I've had to disable MLO in the past to keep stability, keeping it enabled so support can help troubleshoot another issue I had with MLO not working, my only MLO capable device gets rejected on the 5ghz band (MLO only enabled on 5ghz and 6ghz, 2.4ghz dedicated to IOT devices).
I have 4xNWA130BE, two of them so far has panic'd.
- 415 Beta Program
- 2.3K Nebula
- 141 Nebula Ideas
- 94 Nebula Status and Incidents
- 5.5K Security
- 216 USG FLEX H Series
- 262 Security Ideas
- 1.4K Switch
- 71 Switch Ideas
- 1K Wireless
- 39 Wireless Ideas
- 6.3K Consumer Product
- 243 Service & License
- 382 News and Release
- 81 Security Advisories
- 27 Education Center
- 8 [Campaign] Zyxel Network Detective
- 3K FAQ
- 71 Security Highlight
