[Release Note] Zyxel Access Point - V7.00 Patch 3 firmware has been released
Access Points Firmware Release Note
October 2024
Overview
This document provides firmware release information on Zyxel Access Points platforms, introduce new Access Points, new features and enhancements, bug fix, known issues and workarounds information for Release V7.00 Patch 3 C0.
Supported Platforms
(Click Hyperlink to download the firmware directly)
WiFi 7 model(s):
Zyxel WBE660S - V7.00(ACGG.3)C0
Zyxel WBE530 - V7.00(ACLE.3)C0
Zyxel NWA130BE - V7.00(ACIL.3)C0
New Features and Enhancements
N/ABug Fix
Bug fix | C | M | S |
1. [eITS: 240600705] [Symptom] Stations on certain SSIDs can't ping each other | V | V | V |
2. [eITS: 240700214] [Symptom] SSID schedule doesn't start correctly | V | V | V |
3. [eITS: 240801694] [Symptom] Layer 2 isolation not working as expected when using dynamic VLANs | - | - | V |
4. [Symptom] Enabling MLO may occasionally cause the WLAN interface to temporarily go down | V | - | - |
Known Issue
Known Issue | C | M | S |
1. [eITS: 240901112] [Symptom] MLO disabled on Nebula but enabled on AP | V | - | - |
2. [eITS: 240900715] [Symptom] Default SSID appears after Nebula AP update | V | - | - |
3. [eITS: 241000129] [Symptom] Device kernel panic reboot | V | V | V |
Limitation of Settings
N/A
Hi, since update (NWA130BE) i saw something like a system crash. SSID offline, Services restarting.
Log attached.
Next one:
2024-10-22 14:05:11Zyxel-IndoorSystemThe AP has successfully booted.
2024-10-22 14:05:11Zyxel-IndoorZyxel One NetworkZDP: initial port 2 control block
2024-10-22 14:05:11Zyxel-IndoorZyxel One NetworkZDP: initial port 1 control block
2024-10-22 14:05:08Zyxel-IndoorSystemDevice is rebooted by kernel panic!
Sigh my Kernel panics are back again as well. I've had to disable MLO in the past to keep stability, keeping it enabled so support can help troubleshoot another issue I had with MLO not working, my only MLO capable device gets rejected on the 5ghz band (MLO only enabled on 5ghz and 6ghz, 2.4ghz dedicated to IOT devices).
I have 4xNWA130BE, two of them so far has panic'd.
Hi Melen, is enabeled. Regards, Christian
Mine is as well. I was informed that the fix is slate for January's release.
I'll be disabling MLO in the meantime
I've been getting them as well. I feel like I had them often when in Stand Alone mode. After switching back to Nebula I still got them but less frequent. I noticed the it was going into limited power mode as well and tuning off WLANs. I don't know why but I enabled the Override Full Power setting and I haven't had any Panics since.
Hi @Chris888,
I apologize for the delayed reply. I checked your event log but there are no logs related to "kernel panic" after you register to Nebula. May I know if you encounter any problems after registering to Nebula? Please feel free to let me know. Thanks.
Zyxel Melen0 -
No Problem, i wait for the next update.
- 415 Beta Program
- 2.5K Nebula
- 152 Nebula Ideas
- 102 Nebula Status and Incidents
- 5.8K Security
- 305 USG FLEX H Series
- 283 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 255 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.7K FAQ
- 77 Security Highlight
