[Release Note] Zyxel Access Point - V7.00 Patch 3 firmware has been released
Zyxel_Melen
Zyxel_Melen Posts: 3,069  Zyxel Employee
edited January 22 in WirelessLAN New Release
Access Points Firmware Release Note
October 2024
Overview
This document provides firmware release information on Zyxel Access Points platforms, introduce new Access Points, new features and enhancements, bug fix, known issues and workarounds information for Release V7.00 Patch 3 C0.
Supported Platforms
(Click Hyperlink to download the firmware directly)
WiFi 7 model(s):
Zyxel WBE660S - V7.00(ACGG.3)C0
Zyxel WBE530 - V7.00(ACLE.3)C0
Zyxel NWA130BE - V7.00(ACIL.3)C0
New Features and Enhancements
N/A
Bug Fix
C=Cloud mode, M=Managed, S=Standalone mode
Bug fixCMS
1. [eITS: 240600705] [Symptom] Stations on certain SSIDs can't ping each otherVVV
2. [eITS: 240700214] [Symptom] SSID schedule doesn't start correctlyVVV
3. [eITS: 240801694] [Symptom] Layer 2 isolation not working as expected when using dynamic VLANs--V
4. [Symptom] Enabling MLO may occasionally cause the WLAN interface to temporarily go downV--
Known Issue
Known IssueCMS
1. [eITS: 240901112] [Symptom] MLO disabled on Nebula but enabled on APV--
2. [eITS: 240900715] [Symptom] Default SSID appears after Nebula AP updateV--
3. [eITS: 241000129] [Symptom] Device kernel panic reboot VVV
Limitation of Settings
N/A
Zyxel Melen
«1
