NWA130BE restarting
My NWA130BE does a restart several times per day.
It always starts like this:
Netconf connection is connected.
NTP update has succeeded.
Device is rebooted by cold start!
The AP has successfully booted.
Firmware is V7.00(ACIL.3) (Latest)
Maintenance is scheduled for once a week
Any ideas?
            Hi @XForce After reviewing your AP’s event log, it appears that your AP is experiencing several cold starts event within a day, which may be related to the power supply. Could you please try replacing the power adapter for the NWA130BE? It requires a DC input of 12VDC / 2A. Additionally, we noticed that your AP is linked up at 100M. To maintain better network performance, please consider changing your Ethernet cable or connecting your AP to a different port on the modem to see if that improves the situation. Kay 0
            Hi @XForce To help us understand your situation better, could you please provide some additional information? - Could you describe your network topology, particularly any devices connected above your AP?
- Have you recently made any changes to your network configuration, such as adjustments to firewall rules, network settings, or security protocols?
- When did this issue start? Was it present from the initial setup, or has it developed recently?
- How is your AP powered? Are you using a power adapter or PoE?
 Additionally, please enable Zyxel Support access on Nebula CC and provide us your Nebula org and site name, so we can assist with further troubleshooting. Kay 0
            Hi Kay, - there is a AVM Fritz box acting as vdsl2 modem, the connection is fine.
- I did the recent firmware update
- Around the time i did the update
- It is powered via power adapter 12v/30w
 I enabled the Zyxel Support access. Because this is my only zyxel device I chose just a generic "no" as org and site name, i hope that's not a problem, i can change it to something more unique if that helps. thank you for your help so far. 0
            Hi @XForce We couldn’t locate your organization/site "no/no" in our Zyxel Nebula Support list. Could you please confirm if the Zyxel Support access is enabled successfully on your end? Kay 0
            Hi Kay, the supoort access is enabled. It is listed unter Administrators and says latest access time utc: 2024-10-29 02:32:06 looks like you found it? 0
            Hi Kay, Thats good to hear. I hope you can find anything, it just restarted again. 0
            Hi Kay, thank you for your suggestion. I swapped the power adapter to an identical one with 12VDC / 2.5A. Everything works fine so far. Awesome support, thanks again. 1
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 497 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
