Nebula Active Directory Authentication Group Attribute
Mk88_it
Mk88_it Posts: 76 image  Ally Member
i'm trying to configure Nebula Authentication Server linking my AD server, the integration works as aspected except for Group Memeber Attribute.
In my AD server i have a group called (CN) domain.local/group/WifiGuest, so I wrote in the field the name ""WIfiGuest" but if i try to login with an user included into that group, Captive portal says "auth denied" and in to nebula log i see this message "Failed login attempt to Device from http/https (incorrect password or inexistent username)"
I tried anything but i didn't figure out from this issue.
Could you help me please?
  • Mk88_it
    Hi, NCA is right for "FreeWifi" interface. I'm using AD auth for the interface called "hotspot" as you can see.
    However I think I found my mistake: the selected AD Group i would use for auth must be indicated in the "External User Group" section not in the custom options for the "my ad server" section
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,319 image  Zyxel Employee
    HI @Mk88_it ,
    To better assist you, please provide:
    1. Your Zyxel device model and firmware version
    2. The username and login timestamp used for Captive Portal access
    Additionally, please enable Zyxel support and provide us with the name of your Nebula organization/site here or via the private message by clinking to my account > Message.
    Zyxel_Judy
    Untitled Image
  • Mk88_it
    Hello Judy thanks for your answer,
    1- ATP 500 V5.39(ABFU.0) managed from nebula
    2- login username I used: testuser (windows domain user)
    I also enabled Zyxel support access and sent you a private message
  • Zyxel_Judy
    Hi @Mk88_it ,
    Your current Authentication method, which is set to "Sign-on with Nebula Cloud Authentication," is preventing AD server users from connecting to the network.
    To set up AD authentication for the Captive portal, please follow these steps:
    1. Go to Firewall > Authentication method
    2. Select FreeWifi Interface
    3. Under Sign-on, choose "gallini"
    4. Click the Save button
    Zyxel_Judy
    Untitled Image
  • Mk88_it
  • Mk88_it
    Ok this is the solution.
    I have only one question: where i can see the AD users connected to that captive portal?
  • Zyxel_Judy
    Hi there,
    As discussed in our private messages, you can check the event logs to see which AD users are connecting through the captive portal.
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
