Zyxel Router/ATA 3301
I am helping a user with the zyxel 3301 router/ata. I logged into the router and cannot see the VoIP setting heading on the right menu. I can see the voip status under network settings. How can i register a sip account then? Where do i activate voip or voip settings?
Thanks.
VV
Hello VV @VoIP2022
Welcome to the forum.
If the Zyxel device is a DX3301-T0, then a user guide with mentions of SIP in it is at https://support.zyxel.eu/hc/en-us/articles/5858783065362-User-Guide-AX-DX-PX-3301-T0-Serie-V5-13-5-50
I hope that this is helpful.
Kind regards,
Tony
Hi Tony,
Thanks for sharing the manual. But the manual assumes the "VoIP Settings" button is there and instructs how to use it to set VoIp. But, in this case, teh "VoIP Settings" button is NOT there. It is NOT visible on the menu that appears vertically to the right. To me, it seeems like it DISABLED because there are two physical FXS ports. How to ENABLE it so "VoIP Settings" button becomes visible?
Hello VV @VoIP2022
You're welcome.
VoIP should be in the Navigation Panel, see below.
I am going to ask the usual next question, namely can you please say what firmware version the Zyxel device is running?
Kind regards,
Tony
Same problem on my DX3301-T0 like this: "But the manual assumes the "VoIP Settings" button is there and instructs how to use it to set VoIp. But, in this case, teh "VoIP Settings" button is NOT there. It is NOT visible on the menu that appears vertically to the right. To me, it seeems like it DISABLED because there are two physical FXS ports. How to ENABLE it so "VoIP Settings" button becomes visible?"
My default user is "admin", firmware is V5.50(ABVY.3.1)C0 and my ISP is Turk.net (Turkish). I need help.0
- 216 Nebula Ideas
- 570 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
