Zyxel AX7501-B1 disable led blinking
aschmidch
in Home Router
Is it possible to disable the led blinking on a Zyxel AX7501-B1.
I found the command:
ZySH> sys ledblinking off
But that didn't work. Any ideas?
Update to the latest firmware V5.17(ABPC.5)C0
Click on the LED button ON/OFF.
I upgraded to this firmware, but have overseen the menu change for the led.
Thanks for pointing me to it, it works.
- 603 USG FLEX H Series
- 481 News and Release
