NAS326 delete files and folders random! How to solve this?
Hi to all, my Zixel 326, it's deleting files randomly since 2 year. Seems the problem is on a specific shared folder. Today The NAS removed randomly an entire folder with a lot of files inside. The folder simply disappear. I've the Bin enabled on this folder and I can't find it neither in it.
There's a fix for this behaviour?! I've the last updated for all firmware and app.
This is really crazy!? 😡
I can think of 3 reasons why files disappear.
- Filesystem errors, maybe caused by disk problems.
- Serverside software.
- Clientside software
Filesystem errors are unlikely. It wouldn't limit itself to a single share (unless that share is the only one on an unhealthy volume), nor would it only cause files to disappear. It would also corrupt files.
Could be server side software. Is there anything special on that share? Default dump place for a torrent client, or something like that?
When it's client side software I'd look in usage and permissions. Is that share used by your 5 years old daughter? Do you expose that share using another protocol than Samba? (I think the bin only works for samba access). When you enabled FTP for that share, exposed that via internet, and did not provide a decent password, it's to be expected that strange things happen.
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
