WAC6503D-S power problem with Cisco Switch WS-C2960X-24PD-L [solved]
Zyxel_Joslyn said:Hi,We are using a VPN100 as a controller for the WAC6303's and wish to continue doing so.I suppose I would just need the firmware for the WAC6303 so I can distribute and apply it through the VPN100 using the command "capwap firmware-update source DF-Firmware".The only problem we are experiencing is that the AP's only gets limited power and not Full.Thanks
Hi @norwegiansalmon,
Already send you the DF link via the private message. Please check your inbox and let me know if it helps.
Thanks.
Joslyn0 -
Same problem with WAX510D with Cisco 2960X-48LPS-L (370w). 8 units deployed and appears with "limited power" in nebula power mode. Tryied to disable CDP and force ports to 30w consumption.
Any solution for that?
Thanks0 -
Hi @amra
Can you help to check if there is an option as "LLDP-MED" on the Cisco switch? This option should be enabled to let the power negotiation smoothly. If possible, can you provide us your org/site name and enable ZYXEL support(HELP>Support request) for us? We will check the power mode.
Joslyn0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
