FWA710, which has a very strange habit
laser21
laser21 Posts: 2 image  Freshman Member
Hi, I have a FWA710, which has a very strange habit - I have a 5G simcard in it, have around 92dba signal. I have it connected to a unifi dreammachine, which has a connectivity log. When the network is idle - noone is at home, so minimal traffic, all works fine. When we start to do something - browse the web, play some streaming, it starts to have disconnects every few minutes (3-7). We loose internet for around 20-30seconds, then all starts to work again. Only to lose it after a few minutes again.
I tried removing the unifi - connecting a laptop directly to the modem - the behavior is the same.
Im on the newest firmware. What can we try to do? A remote session? Thanks
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Zyxel Employee
    Hi @laser21 ,
    To help us diagnose your case, please try these troubleshooting steps if possible:
    • Insert a different 5G SIM card into your FWA710 and check if the issue persists
    • Insert your original 5G SIM card into another mobile router and check if the issue occurs
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
