WX5600 extender - slow speed & solid amber WPS
AdamUK
AdamUK Posts: 2  Freshman Member
edited November 2024 in Home Router
I have purchased the above wx5600 extender for use with an EX3301 router (router provided by Hyperoptic UK).
The extender connects with the router, and I can create a mesh with the MPro app. However:
  1. The download speed is extremely slow, around 10mbps versus 500mbps direct from router (wireless)
  2. The WPS light on the extender is solid amber
Perhaps #2 is causing #1?
Thank you
  • Liba
    Liba Posts: 205  Master Member
    First Comment First Answer Second Anniversary
    May need to upgrade to the latest firmware.
  • AdamUK
    Thanks Liba.
    I am trying to update the firmware on the wx5600-to but I keep getting an error message:
    "iMAGE UPLOADING FAILED. THE SELECTED FILE IS AN ILLEGAL IMAGE UPLOAD"
    I downloaded the firmware file directly from the Zyxel product page. I have opened the zip file and am trying to update using the .BIN file V570ACEB32C0.bin
    I have tried updating via Safari and Chrome. My laptop is a MacBook Pro.
    current firmware: V5.70(ACEB.2)b4
    latest (but unable to update): V5.70(ACEB.3.2)C0
    ANY FURTHER ADVICE?
