Enable wireless bridge
saltet
saltet Posts: 76 image  Ally Member
edited November 2024 in Nebula
Hi.
I am for first time using on my NWA130 wireless bridge.
I am using Nebula to control my network with total six NWA 130.
Two questions
Which port should I use when connecting a device ? Wan port or Lan port. Does it matter which port I use ?
I am running the device on mesh mode connecting wireless to an other NWA 130
Can I see in Nebula that I have a device connected to a port with wire ? I can’t find that option. Using base pack in Nebula.
Best regards.
Best Answers
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,347 image  Zyxel Employee
    Hi @saltet ,
    The NWA130BE can function in two ways:
    1. As a Root AP:
      • When its uplink port is connected to network devices like a modem, router, or gateway
      • This configuration makes it act as the root access point
    2. As a Repeater AP:
      • When it connects wirelessly to a Root AP
      • It extends the wireless network coverage by repeating the signal
    To connect devices like laptops to the NWA130BE, use its LAN port.
    For setting up Smart Mesh connections on Nebula, please refer to this FAQ:
    [Nebula] How to extend wireless coverage by configure smart mesh? — Zyxel Community
    Currently, there is no feature available to monitor or view which devices are physically connected to the NWA130BE's LAN port via Ethernet cable.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @saltet ,
    Welcome to the Nebula Idea section, where your suggestions could become new features for Nebula. Please share your ideas there so other Zyxel Community members can vote and provide feedback.
    Nebula Ideas - Zyxel Community
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @saltet ,
    1. As a Root AP:
    Zyxel_Judy
    Untitled Image
  • saltet
    Thanks a lot for answers.
    A suggestion is to develop a function to make it able to se what device is connected to the port when using ap with wireless bridge.
  • Zyxel_Judy
    Hi @saltet ,
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
