I have 2 model of zyxel - (1) USG FLEX 700H (2) ATP200
mandeep
mandeep Posts: 4 image  Freshman Member
@Zyxel_CSO: Will both firewalls, the USG FLEX 700H and ATP 200, use the same commands over SSH to fetch details such as user information, zone details, and other settings? Could you provide a list of Zyxel models that use the same SSH commands for retrieving such details?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,954 image  Guru Member
    Hi @mandeep,
    The CLI commands in these two models are not fully the same. I recommend checking the CLI reference guide for more details.
    1. USG FLEX 500H_V1.30.pdf
    2. ATP200_V5.38_Ed2.pdf
    In addition, the ATP and USG FLEX series have the same CLI commands. The USG FLEX H series is not entirely the same as the ATP and USG FLEX series.
    Zyxel Melen
Nebula Tips & Tricks
