Xs1930-10 flow control?
Hi.
I recently bought an xs1930-10. I'm trying to establish what the default firmware setting is with regards to flow control. I can't see it in any menus on the port setup and I asked support via a question but didn't get a answer either.
Does anybody know if its on or off or doesn't exist on default setup?
I have implemented the switch within my 10gb network so am trying to establish what is the best practice with regards to flow control within a 10gb network for this switch and what it's default setting is.
Many thanks for any help
Hi @Skyeci26 ,
Please note: The XS1930 does not currently support Flow Control when managed through Nebula. If your Nebula switches support Flow Control, you can configure it at Configure > Switches > Switch Port.
Please refer to the table below for a list of Nebula switches that support Flow Control:
Zyxel_Judy
Hi @Skyeci26 ,
We believe that your XS1930-10 is managed by Nebula Cloud, so flow control configuration is not available locally. When an XS1930-10 is managed by Nebula, you must access the Nebula portal to implement switch settings.
Zyxel_Judy
How though. I can't find any menus relating to flow control anywhere.
Hi @Skyeci26 ,
Zyxel_Judy
OK thanks. Your chart confirms the xs1930 I have doesn't support it.
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
