NR5101 modem module firmware update
I have RG502QEAAAR11A03M4G on my NR5101, which one is the newest ? Where can I download the newest one ?
Thank you.0 -
I also would like to have the latest version from Nr5101. Right now I am on RG502QEAAAR11A03M4G.
I think that the modem update file for the NR5101 is linked from nsmith's post above on January 16.
Kind regards Tony
This is the FW Zyxel gave me for the NR5101:
This is the spreadsheet for the module CA capabilities with this firmware, it can't do low and high band 5G bands together but can do low & low, high & high (n78+n78 for example)
Hi
I have nr5101 as well, could you tell me your experience with the module update sent to you by zyxel support?
And can You send me the file please or post a link to download it?
It worked without issues on my NR5101, the dropbox link in my post above will provide you the *.img file.
What's new in firmware V1.00(ABVC.10)D0 ?
Any changelog ?
Hello, it is not possible to update to the latest firmware V1.00(ABVC.10)C2, factory setting does not help.
I have to say, software management from zyxel, as well as release notes, finding the correct Software for my module etc. is really bad. Other brands handle this topic much better…
- 234 Nebula Ideas
- 6.7K Security
- 727 USG FLEX H Series
- 372 Security Ideas
- 57 Wireless Ideas
- 7.1K Consumer Product
- 318 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
