I have 2 model of zyxel - (1) USG FLEX 700H (2) ATP200
mandeep
mandeep Posts: 4 image  Freshman Member
@Zyxel_CSO: Will both firewalls, the USG FLEX 700H and ATP 200, use the same commands over SSH to fetch details such as user information, zone details, and other settings? Could you provide a list of Zyxel models that use the same SSH commands for retrieving such details?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,602 image  Zyxel Employee
    Hi @mandeep,
    The CLI commands in these two models are not fully the same. I recommend checking the CLI reference guide for more details.
    1. USG FLEX 500H_V1.30.pdf
    2. ATP200_V5.38_Ed2.pdf
    In addition, the ATP and USG FLEX series have the same CLI commands. The USG FLEX H series is not entirely the same as the ATP and USG FLEX series.
    Zyxel Melen
  • Zyxel_Melen
    Hi @mandeep,
    Zyxel Melen
  • mandeep
    @Zyxel_CSO Thank you !! for providing the CLI reference guide. If it is possible then could you provide the API Documentation of ATP 200.
  • Zyxel_Melen
    Hi @mandeep,
    What function of the API document are you seeking? From my understanding, there is no API document for standalone mode.
    Zyxel Melen
  • mandeep
    @Zyxel_CSO , Acutally I want to finding the details in my network of users, zones, groups, license, networks, interfaces, rules from atp200. If there any API documentation or cli-commands for that. Could you provide which will hep me a lot!! Thanks.
  • Zyxel_Melen
    Hi @mandeep,
    You can get the information you need from CLI command. Please reference the CLI reference guide for more details.
    https://download.zyxel.com/ATP200/cli_reference_guide/ATP200_V5.38_Ed2.pdf
    Zyxel Melen
Nebula Tips & Tricks
