increase IPS range
Gel
Gel Posts: 35 image  Freshman Member
edited November 2024 in Security
I need to increase my IPS range from 254 ips to 512, how can I do this configuration on the Firewall Flex 200?
Would it just be changing the Subnet Mask to 255.255.254.0 and the Pool Size to 512?
    PeterUK Posts: 4,446 image  Guru Member
    Because your on 192.168.10.1 the change to this subnet is not a problem if your IP was 192.168.9.1 then the gateway may need to be changed to 192.168.8.1 due to how subnet IP is done
    So with the change you need to increase the IP pool if needed
    Here is a subnet tool
    Subnet Calculator - Tech-FAQ
