Flex 700H reboots and issue
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,128
    image  Zyxel Employee
    Hi @juewerner,
    Could you share what SFP module are you using?
    Zyxel Melen
  • juewerner
    juewerner Posts: 5
    image  Freshman Member
    I use the original DAG 10 Gbit Patchcabel from Zyxel
  • juewerner
    juewerner Posts: 5
    It is not possible to setting the negotiaton for port 13 oder port 14 - this option are available only for the copper ports.
  • ticsystems
    ticsystems Posts: 87
    First Answer First Comment Friend Collector Sixth Anniversary
    image  ZCNE Certified
    Previously firmware you can change it.
    Try changing it from the switch.
    I use Zyxel DAC for WAN connection and the only problem I have is that when I connect it the flex 700h reboots.
    This is a known issue for Zyxel
  • Zyxel_Melen
    Update:
    The SFP issue has been fixed in the recent firmware. And the DAC issue only occurred on the Zyxel DAC 3M cable. Therefore, we recommend that users not use Zyxel DAC 3M but Zyxel DAC 1M or fiber SFP instead.
    Zyxel Melen
  • ticsystems
    No. It also happened with DAC 1 meter and other manufacturers.
  • Zyxel_Melen
    Hi @ticsystems,
    What device did you connect with your USG FLEX H via Zyxel DAC 1M? And what is the issue symptom?
    Zyxel Melen
  • ticsystems
    XS3600 and Router Cisco.
  • Zyxel_Melen
    Hi @ticsystems,
    I did a local test "700H connect to XS1930 with Zyxel 1M DAC cable" and my result was successful without any issues. 700H didn't reboot when connected.
    Since you might not use the latest firmware, could you use the latest weekly firmware to test? I will send the firmware to you via community message.
    Zyxel Melen
  • AndyY
    AndyY Posts: 4
    can this be a hardware issue of certain 700h models?
