Nr7101 reconnect time
I've seen this happen, it takes, for me, 4 seconds each time. When you'll get the logs working you should be able to understand better the timing.
Generally speaking, I think the issue might be the implementation by Zyxel as the LTE Modem is also used in other brands of routers like MikroTik that seem faster to reconnect but are maybe less user friendly in their UI.
Yes, i set up it this way, but i cannot see no log here, it's always blank. What the problem?
Exact, Chateu 5G has same modem but few seconds to recconnect! It's obviously zyxel implementation.
When you active the logging it will immediately start writing, maybe nothing happened, like disconnections? Give it a day or so or enable other types of log like security/access to be sure it's working.
Finally got log. Reconnection keeps 50 seconds.
Good morning everyone, I have the same problem. In my case it takes 3 to 5 minutes for each IP change.
The same SIM on another 5g modem of another brand, it takes a few seconds.Has anyone managed to solve the problem?
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
