[XGS1930] Full CLI access?
Best Answers
Hi @MichaelB
XGS1930 is a web-managed switch. It only supports web configuration.
The CLI only allow you to use the "show" command to check switch statistics and table, like: show running-config, show mac address-table all, show interfaces status, etc...
Reminder: You may use "show ?" to display all commands which can be use with show.
Regards0 -
Hi @eddeig,
Since you need full CLI capability, you may consider the XGS2220 series.
For more information, please reference our website.
XGS2220 Series - 24/48-port GbE L3 Access Switch with 6 10G Uplink - Overview | Zyxel Networks
Zyxel Melen0
Hi @MichaelB
Regards0 -
I still have a XGS1930 in use. What would you suggest, if I want a new switch with about the same capabilities as the old XGS1930, but WITH full CLI capability?
Regards,
Eddeig0 -
Hi @eddeig,
Zyxel Melen0 -
Since we have no full CLI on XGS1930, is there some way to speed up setting up "Time Ranges"?
So far I have to set each port separate which takes a lot of tome if you have to configure multiple ports.Kind regards,
Eddeig0 -
By the way… Your datasheet is STILL misleading! See for yourself:
https://download.zyxel.com/XGS1930-28HP/datasheet/XGS1930-28HP_6.pdfIt says "Management through Telnet" - you should mention that you do not have full CLI management via Telnet!
Regards,
Eddeig0 -
Hi @eddeig,
You can consider using Nebula mode. The Nebula control center allows you to select multiple ports and configure the same PoE schedule.
It says "Management through Telnet" - you should mention that you do not have full CLI management via Telnet!Thanks for your input. Please be assured that I will let our switch product team know your input. In addition, the web-managed switches do not support full CLI. They only support monitoring commands.
Zyxel Melen0
- 215 Nebula Ideas
- 569 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
