Nas 542
Nino53
Nino53 Posts: 13 image  Freshman Member
The disk LED is always flashing. I did a factory reset, but the problem did not resolve.
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    Can you access the webinterface? If not, can you when you remove the designated disk?
  • Mijzelf
