Problem with Multy app
ALIASKA72
ALIASKA72 Posts: 3  Freshman Member
Hi. I have problems with my Multy X mesh system. On my iPhone multy app I can’t see my multy network. Tried to reset Multy X, but keep stuck on the adding second Multy or if I choose to finish with one, then on app showing that my primary multy is disconnected. On multy itself is solid white light and WiFi and lan is working. Apple app is latest.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,559  Zyxel Employee
    edited December 2024
    Hi @ALIASKA72,
    Could you share your app version? Did you try reinstalling the APP?
    Zyxel Melen
  • ALIASKA72
    Yes. I reinstalled app. App version is 2.6.1.231012. Phone is iPhone 15 plus
  • Zyxel_Melen
    Hi @ALIASKA72,
    Thanks for the update. Please help to send us the feedback on the Multy APP.
    You can follow the below steps to send feedback on the Multy APP
    Our agent will check this issue after you send it.
    Zyxel Melen
  • p_e_g_o
    p_e_g_o Posts: 11  Freshman Member
    @ALIASKA72 was the Support able to fix the problem? I have the same bug
