Using a Wavlink AP
Have a LTE7490-M904 which works fine. I am now wanting to add a Wavlink AC600 wifi extender configured as an AP. I use an unmanaged switch which seems to work fine. Problem I cannot get the AC600 to access the interent. Have spoken to Wavlink who are useless. The AC600 works fine when connected to another network I have but not the Zyxel mobile phone one. Am I missing something obvious?
You have latest firmware V1.00(ABQY.9)C0 ?
https://download.zyxel.com/LTE7490-M904/firmware/LTE7490-M904_V1.00(ABQY.9)C0.zip
Have now loaded latest firmware but problem still present.
You have a POE injector between your switch and AC600?
I have attached a drawing of how I have it wired up.
Hi
Yes my mistake obviously the LTE uses its 48v psu not 24v as I showed. It does work if I connect a signal from a different router into the switch. That is why I am thinking the LTE is the problem.
Have tried various combinations. Different switch, a managed one, no difference. The Wavlink works fine connected into a different router so again finger of blame points to the LTE. Not so much as in its suitability more in as I think a setting is incorrect.
Do you use router mode or IP Passthrough?
If IP Passthrough try router mode, i think that could be your problem.....
Set passthrough to off and can now access internet. Strangely I set passthrough to on as with it off originally I could only connect one computer to it any more than one and it threw a wobbly. Will see how it goes.
Thanks and have a good Christmas and New Year
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 514 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
