FWA710 - get information about LTE signal via webapi or ssh
marianob85
marianob85 Posts: 3  Freshman Member
Is there any possibility to get information about LTE cell info ( RSSI, etc… ) via SSH, SNMP or web api for Zyxel FWA710 ?
  • Zyxel_Kay
    edited December 2024 Answer ✓
    Hi @marianob85
    Thank you for reaching out!
    Yes, you can obtain LTE cell information (e.g., RSSI) via SSH on the FWA710. Here's how:
    1. Enable SSH access through the web configurator by navigating to Maintenance > Remote Management > MGMT Services and enabling SSH.
    2. Once SSH is enabled, access the device using an SSH client and run the following command to retrieve cell information:
      ZySH> cfg cellwan_status get
    Regarding SNMP, the FWA710 does not support this feature for LTE cell information. Similarly, the Nebula API currently supports monitoring the online/offline status of Nebula mobile router devices but does not provide LTE cell details.
    Let us know if you have any further questions!
    Kay
  • Zyxel_Kay
    Hi @marianob85
    Kay
  • marianob85
    Oo. I hadn't thought to look for such information if cfg section.
    Works like a charm. Thanks!
