DX3301-T0 - using VoIP behind a German FRITZ!Box
I have a FRITZ!Box 7490 as my internet gateway which also provides my phone capabilities.
To connect two phones in my bureau (where I have only an ethernet line to my FRITZ!Box), I want to use the DX3301-T0 as a VoIP gateway. I have created a VoIP device on the FRITZ side, I have IP address as registrar, username and password.
My VoIP configuration you can find as attached images.
I get a lot errors in the log:
Has anybody successfully running a DX3301-T0 behind a FRITZ!Box?
There is always a risk of sip Port errors when you use VoIP twice and parallel with a device behind a Router .
The best way with Fritz box is to make the sip login for all Numbers with the fritzbox in front and these special ones define as Lan IP telephones . Then you connect with the extern device to the fritzbox like to a sip server .
So may be its better to use real IP telephones over Lan like a Grandstream device .
But you can try with the same created login data to use the DX3301-t0 device .
Here is a description to configure for a LAN/WLAN IP Telephone :
https://www.mikrocontroller.net/attachment/73061/IP-Telefon_an_FRITZ_Box_anmelden.PDF
- 222 Nebula Ideas
- 616 USG FLEX H Series
- 53 Wireless Ideas
- 484 News and Release
