Disconnect all the time
saltet
saltet Posts: 59 image  Ally Member
I have a Zyxel system controlled by Nebula.
’My system have 5 NWA 130 be.
Latest firmware.
you have access to my system.
tomas.salzmann@telia.com
’My latest NWA 130 be behave strange as it on my iPad Pro generation 3 all the time connect and disconnect my device.
none of the other apps behave the same. The last one -see below- was bought later compared to the other apps,s
se added copy from my Nebula.
It indicate reason 5.
Do you have any suggestions
The only difference in the set up between the apps is that I also use this ap as wireless bridge.
