Strange Pci Scan nr7101
SELBERG
SELBERG Posts: 373 image  Master Member
5 Answers First Comment Friend Collector Fourth Anniversary
edited December 2024 in Mobile Broadband
Anyone else having the same weirdness with Pci Scan?
It has always been the reverse order at MNC and MCC, but when the error is finally corrected, the incorrect remains.
This oddity is similar on 100ABUV10CO and 116ACCC1CO.
Why @Zyxel_Kay
  • SELBERG
    Tried more than 5 factory reset in GUI but it didn't change anything.
    Did it directly on my device and it worked significantly better.
    So a factory reset in the GUI doesn't seem to do the factory reset properly.
  • SELBERG
  • BrandSafway
    BrandSafway Posts: 22 image  Freshman Member
    Hi Selberg,
    im in the process of updating some of our NR7101 to the latest version and noticed the same issue. What was the command you run to reset it via shell on the router?
  • SELBERG
    Just like in picture……
