Set WAN2 as primary WAN.
SirioGala
SirioGala Posts: 3  Freshman Member
i have an ATP100 configured on nebula cloud.
Two WAN port configured on WAN port (WAN1) and port6 (WAN2)
I need to switch the primary WAN on WAN2, how can i do it?
Thank you!
    PeterUK Posts: 3,892  Guru Member
    You can setup routing policy like
    incoming VLAN10
    next hop WAN1
Nebula Tips & Tricks
