Difference between ZyXel FWA-710-EU0102F vs FWA710-EUZNN1F
Hi @phayze
There is no difference in product features or sales policies between the FWA-710-EU0102F and FWA-710-EUZNN1F. These model codes are primarily used internally for tracking product part numbers. Rest assured, the functionality and specifications are identical for both.
Both models support standalone mode as well as Nebula cloud management. While they work perfectly in standalone mode, we highly recommend adding the device to Nebula for enhanced management capabilities. Once registered on the Nebula Control Center (Nebula CC), you can remotely access the device's web configurator and take advantage of features like scheduled reboots.
Local access remains available if you prefer to adjust settings directly. However, please note that when the device is registered to Nebula, the web configurator login credentials will follow the password set in the Nebula CC site settings.
Kay
Hi @phayze
Kay
- 441 Beta Program
- 210 Nebula Ideas
- 539 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
