LTE 7490 NOT WORKING WITH SWITCH OR AP
sublimerob
sublimerob Posts: 1 image  Freshman Member
Hi, i have recently set up the out door 4g router and i get a good 100mbps out the cable but when i put it into my ubiquiti switch or ap, i get nothing. i no the unifi stuff is working as i have checked it on my network at home
  • Heyho74
    Heyho74 Posts: 2 image  Freshman Member
    I'm not familiar with Ubiquiti hardware, but is it possible that your AP is also a DHCP server? This may be causing a conflict with the LTE7490.
    Either disable DHCP on the AP or set the LTE router to bridge mode (or disable DHCP, can't remember exactly how I did it!)
